data logger to spreadsheet
Hello Guys,
I finally got the fluke hydra (2625) to read temperature and voltage using RS32.  My question is how do I log the readings of the data logger to a spreadsheet? Lets say I want to read 5 channels of temperature and 5 channels of voltages, can I log this to the spreadsheet having 5 rows of temperature and 5 rows for voltages (10 rows total)?  I appreciate all the help I can get.
Thanks!
(3,237 Views)
ravy02,
Boy have I got good news for you! There is an express vi designed to do almost exactly what you're looking for. Check out the express vi called "Write to LabVIEW measurement file.vi". It can be found from the functions palette by going to the File I\O sub palette. It can also be found on the express palette by going to the Output sub palette. I think this will do what you're looking for. To find out definition for each of the parameters inside the express vi, click the help button next to the Cancel button in the express vi dialogue box.
Chris C
Applications Engineering
(3,217 Views)
