VXIPnP Driver Library
I'm using an instrument driver from California Instruments called CIC-RP50 for an AC Generator (801RP). The readme file with CIC-RP50 says that two driver libraries are required for it to work properly. One is the VISA library which I have and the other is VXIPnP. Does anyone know where I can find the VXIPnP library to down load?
Thank you
(3,690 Views)
Two places to check
#2 is for california instrument drivers webpage and will require a user name and password which is free after registration
(3,684 Views)
Thank you for the info!
(3,678 Views)
