difference result between exception message and result from VisaStatusCode
Accepted by HZW
Of course I forgot the link: http://www.isr.cc/index.php?option=com_myblog&show=NI-VISA-Interface-Clear-Work-Around.html&Itemid=3...
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 12
(1,593 Views)
Thank you for the suggestion, but I think it is simpler for me just to take the exception into account
and not the Status value. I'm marking this issue as solved - since the Exception feature is the one I will be using.
Kind regards,
HZW
Message 12 of 12
(1,586 Views)
