dll of the instrument driver can not be loaded
Hi Ala Ayesh,
That specifier, GPIB::30.. seems interesting, check in max if that is the correct name for the instrument.
Thanks!
Chris T.
Message 21 of 24
(1,384 Views)
Hello Mr.Christopher,
actually GPIB::1 was the default value for the resourse address parameter as the driver shows. I tried a lot of things and still didn't find a solution. i have send to you the screen shot for the error that i have got, do you know what causes this problem??
please help
thanks
Message 22 of 24
(1,379 Views)
Hi Ala Ayesh,
How is the device connected to your machine? Through an NI GPIB board?
Thanks!
Chris T.
Message 23 of 24
(1,377 Views)
no actually, it is connected using cecGPIB board.
thanks.
Message 24 of 24
(1,375 Views)
