does gpib-pcII/pcIIa-r bd work in a pentium/drivers on ibm 9037 sysplex timer operational diskette
enduser wants to update an alr 486 pc used as a console between two ibm 9037 sysplex timers to a compaq deskpro 4000 pentium II. Currently only software needed is a ibm dos 9037 operational diskette with drivers for ieee-488 cards and a driver from national instruments on same diskette. Does this board work in pentium machines. When tried gpib lost communications between gpib and console repeatedly causing real time clock problems with connected systems(5). bd assy no is 182270-50. Any info would be appreciated.
(3,120 Views)
The GPIB-PCII/IIA used for DOS, 16-bit applications works with any pentium (or AMD) PC with an ISA slot. You can download the latest GPIB driver from http://www.ni.com/support/install. Hope it helps.
(3,120 Views)
