error -410 when run single measurement example in Keithley 2700 driver
Thank you for the link Alex but it again directs me to the page
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=0470C9F181C02E75E0440003BA7CCD...
from which I have been using the drivers up till now and in which I am having a problem.
Message 11 of 13
(768 Views)
Hi Tushar16, try this
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E93BC659CE034080020E748...
which leads you to http://www.tek.com/switching-and-data/2700-software-0
check the compatibility of the OS and LV version and that you have NI VISA properly installed
Message 12 of 13
(751 Views)
Hi Niarena, thank you for your help.
I am more interested in the plug and play module/drivers. I have been using the ones that described in my previous reply.
I am using ''Keithley 27XX Finite Multi Read/ Single Measurement'' for front and rear panel measurement. As far as the front panel is concerned I can measure all the parameters, But while using the rear panel with 7702 module I can only measure DC Voltages and nothing else (ACV, DCi,DCV,Resistance etc). Every time I try to measure some thing other than DC voltage I get an error message, error-221(Settings conflict). I am attaching the file too.
Message 13 of 13
(741 Views)
