error loading NI-488.2M DOS Helper VXD
With NI-488.2 for win 2000/Me/98 GBIB-USB-A installed in my laptop the following message appears before the laptop finishes booting(only wallpaper displayed)
"Error loading the NI-488.2M DOS helper VXD. Contact National Instruments if the problem persists." After I click on the OK button within the error dialog box, the laptop completes booting and everything appears to work fine. I would like to know what is causing this annoying message so it can be eliminated
(3,286 Views)
This error could be due to the DOS support being enabled. To disable DOS support:
-Go to the "Device Manager"
-Right-click the "National Instruments GPIB Interfaces" and click properties
-Uncheck Enable DOS Support
If you don't have this option, you can also remove the error by starting regedit (Start >> Run, then type regedit) and looking for a registry entry under
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunServices called NI4882MDosSupportEXE. Removing this registry key should remove the error. Be sure to back up your registry before making any changes to it!
Heather S.
(3,286 Views)
