event value change
Hi, I'm using an event loop in a subvi where the event is 'value change' on a control. When i'm running it on the main VI it works, but if the event loop is in a sub VI it doesn't work.
If I change the value of the numeric control in the main VI, will the event loop in the sub VI catch that I changed the value ?
Thx
(3,111 Views)
duplicate post and to the wrong forum.
(3,105 Views)
