failure to install nikal
nikal version 1.4 for use with GPIB-USB-HS, Linux, Mandriva 2007
#   /usr/local/bin/updateNIDrivers
reports:
Kernel has reparent_to_init(): yes
Number of arguments for do_munmap(): 3
pte_offset function: pte_offset_kernel()
Levels in page table: 4
Kernel has remap_pfn_range: yes
USB altsetting name: cur_altsetting
Kernel has usb_get_intf(): yes
Kernel has intf_cache member in usb_host_config: yes
Kernel has ep[] members in usb_device: yes
Kernel exports usb_set_configuration(): no
Units of USB_CTRL_GET_TIMEOUT: msec
Kernel has owner member in usb_driver: no
Kernel has put_page_testzero(): yes
Kernel has mutex method: yes
Kernel has kthread: yes
Storing configuration in Makefile.in
If the values stored are incorrect they can be changed before running make.
Uninstalling NI-KAL (nikal): done
/bin/rm -rf objects
Updating NI-KAL:
 NI-KAL update failed.
etc
I have tried Nikal 1.5 and a similar error.
Adrian
Molonglo Radio Observatory
1152 Hoskinstown rd
Byngendore, NSW
Australia
(3,483 Views)
Hi Adrian,
I looked into your error and noticed that Mandriva 2007 is not officially supported per the following KnowledgeBase:
http://digital.ni.com/public.nsf/websearch/35D2B5E483A001A18625716B005BE464?OpenDocument
However I will look into this issue further for your and report back any findings.
John E.
Applications Engineering
(3,468 Views)
From the system report I can see the following in /var/log/messages:
Jul 24 11:47:29 adios kernel: nikal: version magic '2.6.17-14mdvcustom SMP mod_unload 686 gcc-4.1' should be '2.6.17-14mdv SMP mod_unload 686 gcc-4.1'
My first question is did you recompile your kernel?  Usually this is what causes it to append custom to the name as in "2.6.17-14mdvcustom". The following KB may help you solve the problem.:
Why do I Receive a Version Magic Error When I Install NI Drivers on Mandrake 10.1?
Shawn B.
Use NI products on Linux? Come join the NI Linux Users Community
(3,465 Views)
