gbip with tektronix tds540
Okay, I figured some things out and I am almost there.  The .vi attached collected a 4kHz sine wave and performed an FFT analysis on it.  It then writes the data to a spreadsheet.  The delta X (frequency) is 500.  I need it much smaller than this.  I have looked through the sub-VIs and the FFT function and have not found a place to change the delta X.  Any ideas would be very helpful.
Thank you,
Jay
Message 11 of 12
(1,052 Views)
The hoizontal time base is set with TKDS 5XX Config Horiz.
Message 12 of 12
(1,045 Views)
