genesys
sorry for the delay.
I had solved the problem a lot of time ago.
it was the cable. The genesys needs the original cable. My first cable wasn't the original one and didn't work.
Message 21 of 24
(1,973 Views)
Hello, I'm trying to control the genesys TDK-Lambda 750W power supply through serial communication(Through hyperterminal). I have connected my power supply with the PC using a RS 232 cable with DB25 and Rj-45 connectors. THe power supplu has the following settings:
Bits per second:9600(Default)
Parity :None
Address:06(Default)
For serial communication the power supply is setted to use RS232 in the rear panel.
I have verified the address, the baud-rate, the switches on the rear of the instrument, but it appears all ok.
I have verified the COM in the PC, too..but it doesn't talk with the tdk lambda. when I send "ADR 06" to the power source through hyperterminal it should say "OK", but I read only
ADR 06
ADR 06
I don't know whether the communication port on the power supply is enabled or not.could any please help. Thank you
Message 22 of 24
(1,947 Views)
Hi, the driver link you recommended uses USB as the interface, however, I do not see any USB interface on the GENH powersupply.
Does it mean I should use a RS232 to USB cable and use the driver?
Any advice is welcomed.
Message 24 of 24
(1,467 Views)
