genesys
@tdavison313 wrote:
I'm having the same problem. Rs232 to db9 connector for the TDK lambda gen 150-10. I have the cable connected to com1 but when I go to hyper terminal no responses come from the power supply when j type ADR 06. I know I have the baud rate, data bits etc right but it won't work
Any suggestions?
Are you sure you have the right type of serial cable, straight-through vs. null modem?
Message 11 of 24
(2,847 Views)
I think that might be the problem. From page 77 on the manual posted on the previous page which one should it be?
Message 12 of 24
(2,842 Views)
Yep it needs to be null and mine isn't. I will try that and post back here if the problem persists
Message 13 of 24
(2,839 Views)
It's page 81.
Message 14 of 24
(2,836 Views)
So I changed the wire configurations on my cable to match that in the manual (null with Rx to tx on both). Still, nothing on the hyper terminal. I get the same responses as the original poster for the visa test panel.
Write: return count 6
Return status 0
Error on read
Message 15 of 24
(2,826 Views)
Check to see if the serial port is enabled on the instrument.
Message 16 of 24
(2,824 Views)
I'm trying to do what's on page 90 of the manual
Message 17 of 24
(2,823 Views)
Got it. Thanks! So simple, can't believe I overlooked that
Message 18 of 24
(2,818 Views)
If anyone else has the sane problem. Type in ena on hyper terminal and then ADR n
Message 19 of 24
(2,817 Views)
So I assume the "ENA" command was to enable the remote connection?
Message 20 of 24
(2,805 Views)
