gpib agilent
Hi. I searched in the web and in the manual of the puwer supply but i haven't found istructions how to implement it into NI Labview. Anyone could help me do it? I need to control voltage (up and down in function of the temperature wave of an instrument). Thank you all
(4,319 Views)
I used the Vi attached in this message.
Manually, the power supply works: if i set 2V it gives 2V
With the GPIB control, if i set 2V i read 2V in the program but the power supply gives 0V!
How to fix this?
(4,316 Views)
You haven't told us what power supply you're using, or provided a link to the manual.
(4,308 Views)
you're right, sorry about that.
manual attached.
i solved the problem explained before.
Another issue now: I need to "PID" the voltage based by a temperature value, that assume a costant value, sine waveform values, casual waveform values. Don't know how to PID the voltage..
(4,305 Views)
PID refers to a type of control loop: http://en.wikipedia.org/wiki/PID_controller
You can implement the PID loop yourself (examples have been posted and you can search for them), or you can also purchase the PID Control Toolkit from NI.
(4,296 Views)
