‎02-29-2016 04:47 AM
hi all.
I have 2 identical usb-GPIB adapter, and two different PC with the same acquisition software written in LabView, in the first machine, i can use both usb-GPIB interface with no problems.
on the second PC, the first interface works perfectly, the second one, instead, is recognized perfectly in windows device manager, but when i try to communicate with my instruments, the software says "oscilloscope was not found, check the cable or the instrument", what can i try??
thanks for the support. David
‎03-02-2016 04:58 AM
do you have all the needed drivers also in the second PC?
Which software gives you the error message? Is the LV application? You should check out which condition creates that error.
Kind regards
‎03-02-2016 05:30 AM
‎03-02-2016 06:50 AM
Hi David,
what about posting on italian forum? I think it would be way too better since I am not able to understand your point.
If you are getting troubles with the interface on both the PC the problem is for sure of the interface.
Kind regards.
