how to export data from DPM-3 load cell to LabVIEW
Hi
I want to export the force data from a DPM-3 load cell (Transducer Techniques) to LabVIEW. however, LabVIEW does not recognize the USB port, so it cannot communicate with it. Has anybody tried to define this load cell to LabVIEW?
Thanks a lot
(4,162 Views)
Most likely the harware driver was not installed.  The device should have come with a CD/ DVD and a quick-start guide.  Make sure the device is compatable with your OS from the guide and follow instructions.
(4,145 Views)
Hi Jeff
thank for reply. I have installed the driver software too. however, LabVIEW cannot still communicate with it. In fact the company (Transducer Techniques) has provided an interface to display the force data on screen, and it works. but the problem is that LabVIEW cannot import the data.
Thanks for help in advance
Shayan
(4,127 Views)
You did shut down the vendor interface right?
(4,115 Views)
