gpibprop.dll is missing. Where could be the reason?
Hello.
My problem is: I'm using Agilent Technologies Network analyzer E8361A with Labview. The communication is done by GPIB, and everything works fine.
For some reasons, I need to change the computer I'm using. The new computer has also the GPIB card, so I thought I will just reconnect the Network analyzer, I'll copy the software and that's it.
Unfortunately, my Network analyzer is not seen in the new computer.
I started the 'Measurement and Automatisation' application, but I can't check if my Network analyzer is there, because I get the error that 'gpibprop.dll' is missing. Actually I don't know, where does this file belong to. Is it a part of National Instruments software, or any hardware that is installed on the system? I can't tell since when the file is missing, because I'm not the first user of that computer (but I don't have any contact with the previous user). Can anybody explain me, where I can find 'gpibprop.dll', or what can be the reason, that my Network analyzer is not seen in the new computer?
Thanks in advance
(3,723 Views)
I don't believe that gpibprop.dll is a National Instruments DLL.  It's not on my system (XP, with NI-488.2 v2.4 installed).  It could be a really old DLL.  What version of the driver are you running?  The first step would be to get the latest version and reinstall.
Scott B.
GPIB Software
(3,704 Views)
As far as i found out, the DLL is an old component of the NI-488.2 (about 1999). perharps this link will help in finding a correct driver for your GPIB interface, which supports you with the neccessary DLLs.
Norbert B.
NI Germany
P.S.: i believe that this question is similar to this one.
Norbert
Expert: Geometry
(3,686 Views)
Thank you ALL for your replies. Actually after failure with the new computer, I decided to continue my work with the old-one.
But one reply saying that this file is an old file from 1999 is highly possible, because the system was built at that time.
(3,682 Views)
