gpibprt.ko compile error
Setup:
Using redhat enterprise 5 on a 64 bit dell workstation.  Labview professional 8.6 fresh install.
I need to get NIVISA configured/running to communicate with test instruments on a LAN using VXI-11.
Don't have a GPIB card - all communication/control will be over a LAN/TCPIP.
Problem:
Can't run VISA utilities because module gpibprtk.ko can't be found.
Searching the forums, this seems to be a 64bit / 32bit issue.  Running updateNIDriver and observing the output gets me to this:
/bin/mv objects/gpibprtk.ko objects/gpibprtk-interfaceFile.ko
ld -r objects/gpibprtk-interfaceFile.ko objects/gpibprtk-processed.o -o objects/gpibprtk.ko
ld: Relocatable linking with relocations from format elf32-i386 (objects/gpibprtk-processed.o) to format elf64-x86-64 (objects/gpibprtk.ko) is not supported
make: *** [objects/gpibprtk.ko] Error 1
ERROR: failed to build gpibprtk.ko
 gpibprtk.ko failed to update.
WARNING: could not unload module nipalk from memory
/usr/local/natinst/nikal/src
 nipalk.ko successfully updated.
Update of National Instruments drivers failed.
it would appear that the module is 32bit and won't link to a 64 bit kernel.  I'm by no means the expert on compiling and linking, but the link
error seems to be the central problem - no link =  no module = no workie.
So, I assume I need this module loaded to get my VXI-11/LAN stuff to work even though I'm not using GPIB - at least not the hardware interface.
I've attached the output from updateNIDriver for reference.  All software is from the CD - workstation has no external access - although I can "sneakernet" stuff onto the system.
Any help appreciated.  I'm kinda googled out at this point.
Steve.
(3,747 Views)
Dear sdsmith,
Nice job on doing your research before posting.  That's very much appreciated.
What version of NI-VISA are you using?
Sammy Z.
(3,710 Views)
Accepted by sdsmith
Sammy,
Thanks for the reply.  I was able to resolve the problem as shown below (post from linux users group).  I had also posted the issue in the linux users group.  I marked it as answered there, but forgot to clear it out here.  Anyway, I found that you had to install BOTH updated versions of NIVISA and NI488, then I ran updateNIDriver to compile the module.  That may have been redundent, but the updateNIDriver outputs the results to the terminal so I can see if it compiled, or errored out.
Steve.
Update #2.
I downloaded and installed ni4882-2.5.4b1-release.tar.gz.  This contained the source for ni488k.ko which compiled and installed OK.
VISA interactive utility can now talk to a LXI instrument on the lan, so it looks like we're up:)
I assume the new version of NI-VISA now calls ni488k.ko to be loaded if not there rather than gpibprtk.ko.
I would have thought the driver would have been included in the NI-VISA 64 bit ISO update package since I thought that this is where the orginal 488 source files came from, but apparently, you need both - maybe because the 488 driver is still in beta?
So it appears that I've answered my own question - by installing some updates, but I'll leave this here in case it is useful to someone else.
Since the workstation is stand-alone, the automagic update approach is not an option - the old fashion read the error msg and solve it is required here:\
(3,694 Views)
