hanging visa
hello. i have a big problem visa lab view. my labview give a string code from the microcontroller via a serial to usb converter. my program dont have problem until ,i changed the windows of the pc.then i reinstall labview and visa.but now..when i start to give code and display ,the program is ok and the recived code is display at the front panel. but after the 1 min.. my pc was reset (without error) or  the labview is hang(get data is stop after the 1min)  and  the  labview program dosent stop until , i  separated  the converter (serial to usb)
(4,927 Views)
whixh usb to serial converter do you use?
There are a lot of cheap bad controllers around.
greetings from the Netherlands
(4,924 Views)
The problem of not coverter.because I 've tested the program on the hyper terminal and serial comminication and I do not have a problem .but at the labview....
(4,896 Views)
how this question is known for me I think I answer it before
check your max to see whether your visa is recognize by labview or not
(4,865 Views)
