I COULDN'T CONNECT SINGLE BOARD RIO TO MY COMPUTER
I INSTALLED NI RIO 14 AND FPGA XILINX COMP AND NI DRIVERS AND NI MAX AND STILL I COULDN'T CONNECT THE BOARD AFTER TRYING ALL THE TROUBLESHOOTING METHODS
(4,258 Views)
Fix your keyboard! you have a stuck caps lock key and it sounds like you are shouting.  You will get better help by observing accepted nettiqute
You have highlighted the wrong software component in your picture.  That component is used to allow a remote PC to control a RIO attached to My Computer  Without remote access enabled that -52003 is normal.
The Getting Started Guide tells you how to connect the sbRIO to My Computer starting on pg 5
You may have incorrect firewall settings. See here for details
(4,242 Views)
You can use this document as a simple guide to try to connect a network device:
http://digital.ni.com/public.nsf/allkb/ABE4BC247E8AC9BC8625734E005CAB42
How are you connecting to the device? Directly? Same subnet?
I will recommend you to lower the firewall too.
What sbRIO do you?
Randy @Rscd27@
(4,204 Views)
