how can I communicate to TDS460A via GPIB-USB-HS?
Those are graphs in the VI you posted. I have no idea where you got those from because in the original VI, they are error in/error out clusters. In older versions of LabVIEW, the error clusters were colored red. Now, they are green. That's to make them unique and different from other clusters.
Message 11 of 12
(1,139 Views)
Sorton,
Those 2 icons represent clusters that appear on your front panel.  The reason you can't connect them is because, as Dennis mentioned, you can only connect an Error Cluster, which is a specific type of cluster found on the Array, Matrix & Cluster palette.  They are called Error In 3D and Error Out 3D, respectively.
Chad B. » National Instruments » ni.com
Message 12 of 12
(1,118 Views)
