Sorton,
Those 2 icons represent clusters that appear on your front panel. The reason you can't connect them is because, as Dennis mentioned, you can only connect an Error Cluster, which is a specific type of cluster found on the Array, Matrix & Cluster palette. They are called Error In 3D and Error Out 3D, respectively.
Chad B. »
National Instruments » ni.com
