how can i connect to fluke 199B?
i am trying to connect to fluke 199B Scopemeter, i installed the drivers to use the OC4USB cable's com port and the drivers of the instrument. when i connect the fluke to the usb port, the instrument is detected and i verified this in the MAX software and the communication port is ready to use.
but when i try to run a self test with Labview 9.0 appear a mistake error;
ASLR1::INSTR
Return status code: 0xBFFF0072
status name: VI_ERROR_RSRC_BUSY
after that, i close all communication ports to work only with the OC4USB but i do not have change.
i do not know if the instrument drivers be compatibles, because i installed the instrument drivers to use with Labview 8.0 version and i am running with Labview 9.0.
everybody that have an idea of my problem?
thanks and i hope your assistance.
(3,895 Views)
Hi
The LabVIEW version is not a problem. but it looks if this is a msg from the instrument or the usb port is blocked by another program.
Maybe a testprogram you are also running?
greetings from the Netherlands
(3,890 Views)
Thanks Albert,
I checked and disable all the USB ports that was not in use. I tried again, and when run the application not appear error in the VI application. I do not know what is append.
I don't have answer of the instrument, and any changes are visible in display.
What do you recommend, that I must to do.
Thanks for all..And sorry for don't answer soon...
Greetings...
(3,872 Views)
Hi
According the serial port you use, did you try to communicate with hyperterminal or inside max?
Did you also dowwnload the istrumentdriver from IDN?
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=668
this is the C version but probably compatible.
(3,855 Views)
