how can i handle this problem with HP82350 PCI CPIB CARD IN LAB VIEW
When i used hp 82350 pci gpib card in my computer, i install agilent visa as secondary visa and can fine the gpib port in ni-visa, and it can work, but when i close labview, the camputer always appear a error, and if the program runs 5 minites or longer, i cannot exit labview properly, it needs pressing ctrl-alt-del to exit.why? how can i handle this problem?
(3,365 Views)
What kind of error do you get when you close LabVIEW? You may have only one VISA installed on your computer. So you should make sure that either only HP-VISA or NI-VISA is installed. Refer to the KnowledgeBase at http://digital.ni.com/public.nsf/websearch/E56D3D4866BE0A8A86256942006626F0?OpenDocument for more detailed information on how to do this.
Hope this helps.
Regards.
A. Saha
Applications Engineer
Anu Saha
Academic Product Marketing Engineer
(3,365 Views)
