how can i stop prorgamm which use serial port ?
i want to stop manually....how ?
" Science is came....not come "
I study Mechatronics Engineer
skype : t_alhowaiti
Message 11 of 14
(1,769 Views)
You've got the stop button. What else do you want? The function I mentioned will display elapsed time.
Message 12 of 14
(1,764 Views)
As you don't post your vi, I won't check this thread anymore.
good luck.
Real programmers try to learn from their mistakes, others keep on asking.
greetings from the Netherlands
Message 13 of 14
(1,747 Views)
As was said before, move the Configure Serial Port to before the loop and the Close VISA Session after the loop.  Leave the timeout unwired.  10 seconds is just fine.
Another thing that could help you is the fact that the case structure will accept strings.  Just wire your read data straight into the case selector.  You can then have a case for each of your possible values.  Do this instead of having cascading case structures.  It makes life a lot easier.
Message 14 of 14
(1,742 Views)
