how do I find the int value of nimodinst_attr_device_model
Help,
I am updating my python drivers for our PXI rack, and I am implementing a fuction to get the serial numbers via niModInst_GetInstalledDeviceAttributeViString.
I can see in the help documentation, that this call has the parameter:
attributeID, the type is ViInt32, which is an integer, but the given valid values are:
NIMODINST_ATTR_DEVICE_NAME, NIMODINST_ATTR_DEVICE_MODEL, etc....
where do I find where, or how, these values are mapped to int32 values?  So far I have not been able to find the info.
thanks,
Message 1 of 8
(4,391 Views)
according to niModInst_GetInstalledDeviceAttributeViString
NIMODINST_ATTR_DEVICE_MODEL—the model of the device (for example, NI PXI-5122)
so the typ of NIMODINST_ATTR_DEVICE_MODEL is ViString
Message 2 of 8
(4,378 Views)
No, that is how it is described, but the type for that parameters is listed as ViInt32.  So the type doesn't seem to match the description.  passing a string does not work
Message 3 of 8
(4,374 Views)
//Get the size of the DeviceModel String;For e.g. get size of PXI-5122
     buffersize_devicemodel=niModInst_GetInstalledDeviceAttributeViString (vi, index,NIMODINST_ATTR_DEVICE_MODEL,0, NULL);
attributeID ViInt32 The ID of the string attribute you want to query.
Valid Values
NIMODINST_ATTR_DEVICE_NAME—the name of the device, which can be used to open an instrument driver session for that device
NIMODINST_ATTR_SERIAL_NUMBER—the serial number of the device
Message 4 of 8
(4,366 Views)
The example Using NI-ModInst to query specific information in CVI demonstrates using NI-ModInst to get a list of devices that use a particular driver and obtain useful information about a specific device.
For example, you can use this example program to get a list of devices that use NI-DMM, along with their corresponding device numbers and serial numbers.
Message 5 of 8
(4,364 Views)
Attribute Definitions:
// ViString Attributes
#define NIMODINST_ATTR_DEVICE_NAME                 0
#define NIMODINST_ATTR_DEVICE_MODEL               1
#define NIMODINST_ATTR_SERIAL_NUMBER             2
Message 6 of 8
(4,358 Views)
Thanks for the help, at the moment I just have an issue of setting up the pointer in python correctly, to pass to the DLL, then your suggestions should work.
Message 7 of 8
(4,356 Views)
you're welcome 🙂
I wish you much success
Message 8 of 8
(4,351 Views)
