 Imran Yousaf
			Imran Yousaf
			02-07-2008 08:42 AM
 Albert.Geven
			Albert.Geven
			02-07-2008 03:05 PM
 Devin_K
			Devin_K
			02-08-2008 02:14 PM
 chakos
			chakos
			01-21-2009 05:29 PM
Dear sir,
i am using the dtmf frequencies to make a chat program in labview between computers,
the transmitter sends data in the following format msb(2sinetonesfor 800ms)lsb(2sine tonesfor 800ms)and pause
while designing the receiver i found that i am getting the output on a single line(i mean a single wire... the data comes out ) in the following format :-
msblsb.....msblsb.....msblsb......i want to multiply the msb with 16 and then add it to the lsb ..and then finally print the result
could you be able to help me?
many thanks in advance
have a niece day!
regards,
thomas george
 waloruelas
			waloruelas
			02-16-2011 08:48 PM
Hi Albert..... can you send me the tone detection.vi please because in labview i cant' found it .......thanks!
 Albert.Geven
			Albert.Geven
			02-27-2011 08:55 AM
Hi
maybe you don't have the full development but in case you have
Owning Palette: Waveform Measurements VIs
Requires: Full Development System
Takes a signal in, finds the single tone with the highest amplitude or searches a specified frequency range, and returns the single tone frequency, amplitude, and phase. The input signal can be real or complex and single-channel or multichannel. Wire data to the time signal in input to determine the polymorphic instance to use or manually select the instance.
