how to open the HP428XA Frequency Step Measurement.vi
The llb you posted is in version 5 and has no diagrams so it can not be loaded in a newer version of LabVIEW. The only thing I could do is try to open the file and read it. I used a function in 7.1 called Read From I16 File. This calls the subVI that is giving you the error. I had no problem reading it though I can't tell if the data is correct. Without seeing the source code of your program, I have no idea where the problem could be.
Message 11 of 14
(1,197 Views)
is there a possibility to see the source code? and how?
Message 12 of 14
(1,193 Views)
There is no possibility with the code you posted. Once the diagram is gone, it is gone forever. You would need to find the original VIs - the ones that don't have the diagrams removed.
Message 13 of 14
(1,187 Views)
hi, its again me!
i managed now to see what is in the binery files, but somehow my collegues lost the source code and the block diagramm. now i am trying to find a system in my numbers. i think i have three to four columns, but are not sure. do you know where or how i can find out, how lab view writes binary files?
thanks
Message 14 of 14
(1,144 Views)
