how to run a USB-485/4 in Windows 10
Hi all this community, I have a question which is: I have a USB-485/4 and I want it to work on Windows 10, as I do because when you connect it gives me no response when making connection to the instrument that is connected, will be software or thing which is the right software to make it work perfectly, thanks for your help.
(3,705 Views)
Are you just not seeing the COM ports at all when you connect the USB-485/4?  Did you install NI-Serial?
GCentral
(3,697 Views)
