read from the buffer each (ms) labview visa
hello everyone
i have a data came each millisecond i want to save this data and clear the buffer for the next data
Message 1 of 10
(4,889 Views)
hello everyone
pleas help
Message 2 of 10
(4,902 Views)
Reading the data already clears the buffer. Do you have another problem?
greetings from the Netherlands
Message 3 of 10
(4,881 Views)
pleas can you give me the block Diagrame I needed urgently
Message 4 of 10
(4,866 Views)
What is so hard about a VISA Read inside of a loop with the setup before the loop and the closing after the loop?  Perhaps you should describe your application and what exactly you are try to accomplish.
GCentral
Message 5 of 10
(4,853 Views)
 What i change in this picture?
Message 6 of 10
(4,846 Views)
1. Get rid of the VISA Open.  It is not needed.
2. Move the Configure Serial Port to be before the loop.
3. Move the VISA Close to be after the loop.
Other than that, it completely depends on the instrument you are trying to communicate with.
GCentral
Message 7 of 10
(4,833 Views)
my application :an oscilloscope with microcontroller  ARM  lpc1768 and labview
labview code  does not work
pleas heps
Message 8 of 10
(4,824 Views)
the buffer empty
error
Message 9 of 10
(4,807 Views)
Please connect all error in out connections, they are there to help find errors.
The loss of a connection probably means that you have another connection open from an other program.
Message 10 of 10
(4,783 Views)
