 abdou2016
			abdou2016
			03-26-2016 04:54 PM
hello everyone
i have a data came each millisecond i want to save this data and clear the buffer for the next data
03-26-2016 04:43 PM
hello everyone
pleas help
 Albert.Geven
			Albert.Geven
			03-27-2016 12:28 AM
03-27-2016 03:50 AM
pleas can you give me the block Diagrame I needed urgently
 crossrulz
			crossrulz
			03-27-2016 06:40 AM
What is so hard about a VISA Read inside of a loop with the setup before the loop and the closing after the loop? Perhaps you should describe your application and what exactly you are try to accomplish.
03-27-2016 07:42 AM
What i change in this picture?
 crossrulz
			crossrulz
			03-27-2016 08:37 AM
1. Get rid of the VISA Open. It is not needed.
2. Move the Configure Serial Port to be before the loop.
3. Move the VISA Close to be after the loop.
Other than that, it completely depends on the instrument you are trying to communicate with.
03-27-2016 10:06 AM
my application :an oscilloscope with microcontroller ARM lpc1768 and labview
labview code does not work
pleas heps
03-27-2016 11:44 AM
the buffer empty
error
 Albert.Geven
			Albert.Geven
			03-27-2016 03:17 PM
