how to test PXI -PCI 8331 in MAX
       Hi
             How to check the PXI-PCI 8331 in MAx.I had inserted PXI 8331 card in Chassis with controller and PCI 8331 in my PC acting as a host but in MAX only PXI was identified but not PCI card eventhough card was inserted correctly. So help me out what to do for this and test those cards
       Geetha
(4,613 Views)
Hello Geetha,
PCI-8331 is not detected in MAX. As PCI-8331 is a PCI extender. If you can see the PXI cards in MAX, means you are able to communicate with the chassis and your system is setup correctly. In case if you still have problem communicating with the card in the Chassis have a look at this knowledge base, this may help. Let me know how it goes.
Thanks and good luck with everything.
Regards
Nikhil A.
(4,603 Views)
Hello Nikil
        Thanks a lot
               Its working what r the commands i can give to communicate with those devices .
(4,589 Views)
Hello Geetha,
Its great that it's working. About the second question, what cards are you using? Depending on the cards you can communicate with them using the appropriate driver.
Regards
Nikhil A.
(4,582 Views)
Hi
           I am using PCI-PXI 8661 Card and using my PC as host with PCI 8661 ,the other chassis with controller and only with one card i.e, PXI 8661.So what are the commands i can give
Message Edited by AutoTEC on 05-24-2007 12:56 AM
(4,572 Views)
Can you confirm the Model # again is it PXI-PCI 8361 as the one you have mentioned is not NI card.
Regards
Nikhil A,
(4,555 Views)
Hi
  Sorry the card which i am using is PCI PXI 8331.
(4,547 Views)
