hp8751an old low frequency network analyzer
Is it possible to acquire the measured data from an HP8751A?
We have a National Instruments GPIB-USB_HS cable.
Do we need software and drivers to acquire the measured data?
Sincerely,
leon
leon@fairviewmicrowave.com
(3,553 Views)
Sincerely,
leon
What programming language are you using?
I have controlled instruments without using instrument drivers. In generaly, I don't use them.
(3,551 Views)
In general it is a good idea to start with an instrument driver when available.
You can also do a lot of assembly or write your own operating system.
greetings from the Netherlands
(3,541 Views)
