iberr(EABO) 6 : GPIB control error
increase the GPIB bus to 2us; timeout to 30s; The same problem.
I did experiment: after each write, re-communicate with equipment(9070), new write will work. pls see attachment spy file.
Can I apply it(re-initialize code)  to VB code as "dummy" command between two writes to prevent the error pop up? But, will 9070 could memorize the old writes?  Thanks!!
Message 11 of 11
(1,638 Views)
