install error message
what is the error message?
K:\NIInstallers\trunk\1.2\src\UberInstaller\UberInstaller.cpp(1096): IInstallerError 10009
Fatal Error. Unable to create temporary file.
Unable to copy original D:\supportfiles\nipie.exe to C:\DOCUME~1\ADMINI~1.000\LOCALS~1\Temp\nii25.tmp.
Windows Error Windows Error 999: Error performing inpage operation.
Exception code: E06D7363 ()
Fault address: 77E59B01 0001:00008B01 C:\winnt\system32\KERNEL32.DLL
Registers:
EAX:0012F69C
EBX:0000000C
ECX:00000000
EDX:0051ED38
ESI:0012F72C
EDI:0012F6BC
CS:EIP:001B77E59B01
SS:ESP:00230012F694 EBP:0012F6EC
DS:0023 ES:0023 FS:0038 GS:0000
Flags:00000206
Stack Trace
Address Frame LogicalAddr Module SymbolName + Offset
77E59B01 0012F6EC 0001:00008B01 C:\winnt\system32\KERNEL32.DLL RaiseException + 85
004D0E5F 0012F72C 0001:000CFE5F D:\setup.exe
0046BD23 0012F820 0001:0006AD23 D:\setup.exe
0046C33D 0012F848 0001:0006B33D D:\setup.exe
0040DC14 0012FAC8 0001:0000CC14 D:\setup.exe
00410783 0012FB78 0001:0000F783 D:\setup.exe
004694A4 0012FDA0 0001:000684A4 D:\setup.exe
0046D96A 0012FDDC 0001:0006C96A D:\setup.exe
0046D2CE 0012FF10 0001:0006C2CE D:\setup.exe
004F9A07 0012FFC0 0001:000F8A07 D:\setup.exe
77E57903 0012FFF0 0001:00006903 C:\winnt\system32\KERNEL32.DLL SetUnhandledExceptionFilter + 92
(3,970 Views)
Hi ,
I'd take this as a serious warning sign. There is something wrong in your PC, either HW or Windows. There are seceral things to mention:
This looks like you are using an administrator account, which is not a good idea as it opens all gates to the system for you and anybody acting with your account (someone getting accesss to your desk in your absense or via the net)..
Than, your account name is
'ADMINI~1.000'. This might be a sign of a corrupted account ADMINI~1' that has been recreated using the extension '000'. Allthough this might work for a longer period, you may want to re-install your whole system in the near future.
An inpage operation is performed when any data had been removed from RAM to the swap file and is later needed again. Before the process in need of that data can access it, the system loads it again from the swap file into RAM and directs the process to that data.
This did not work here. There might be several reasons. Your hardware might be faulty. Most probably it is the hard disk. Perform a backup of your system! Let windows check the hard disk (UNCHECK search for bad sectors!).  You may also perform a defragmentation, but this is more a means to speed up the access rather than clearing any faults. A last resort (Caution, may take several hours!) is a check with checked 'search for bad sectors).
As you are working with a recreated admin account I'd assume the provbability of a corrpited system is much higher.  This means a backup of your whole system and a formatting of all your hard disks. Afterwards you have to reinstall your Windows and all your apps. After that copy your private data and maybe some konfiguration files back to the new system.
A lot of work, but I see no alternative
Greetings from Germany!<br>-- <br>Uwe
(3,963 Views)
What are you installing? What operating system?  What other NI Software is on the system?  If you're installing from a network share, copy the files locally first.
Scott B.
GPIB Software
(3,957 Views)
