instrument drivers
Hey
I have a Chroma AC power source model 61600 series. I am looking to install a driver from labview should i install the chr61xx series the options are
chr61xx
chr6310
chr640x
chr6430
chr6490
chr65xx
Currrently i do not have access to the chroma as it is being used by another application. However, none of these drivers say they support windows 7. Any insight is welcome thanks.
Damien
(3,929 Views)
Unless the driver is a DLL, which version of Windows you are using is irrelevant.
(3,925 Views)
Accepted by Damien129
There is the 616xx driver so I don't know why you would not download that. It says windows only. I don't see anything about windows 7. Do you really mean 64 bit?
p.s. Writing a power supply driver is actually pretty trivial if you don't want to use IVI.
(3,922 Views)
Thanks for the info yeah its 64 bit. I found that driver.
Damien
(3,901 Views)
