JuanCarlos,
Thanks for you help. Since I have been getting this error, we did some system monitoring and noticed that when the system crashes, the CPU is running at 100%. It also crashes during debug mode as well. I have been putting in break points to specifically find a location. What we have come down to is that its writes the test information to a file, but crashes when the file is recalled within the program to process some results. As far as GPIB drivers, everything is correctly installed and since we are using old ISA slots, I have made sure there are no IRQ conflicts.
The funny thing is...this exact program works perfectly fine on another station but crashes on this current station! We need both fully functional though.
Is there a
nything I should look for specifically to tell if its a GPIB problem? Anything specific for CVI problems?
Thanks for you help!
Paul
