keithley 2306 second channel ?
I've downloaded the IVI driver for the KE230x, but it fails to recognize my Keithley 2306 (fails on init with idquery=1). When started with idquery = 0, I am only able to use the channel 1. Any ideas ?
(3,362 Views)
Initialize driver with InitWithOptions and use "DriverSetup=Model:2306"
ke230x_InitWithOptions("GPIB::10::INSTR",
VI_FALSE,
VI_FALSE,
"Simulate=0,RangeCheck=1,QueryInstrStatus=1,Cache=1,DriverSetup=Model:2306", &vi);
DriverSetup you can specify in MAX too. Every Virtual Instument has Driver Options entry. In max use only "Model:2306" without quotation marks.
When you don't specify Model in Option String or you skip ID Query, driver does not detect instrument and default instrument is KE 2302.
2) What does instrument return for "*IDN?" in VISA interactive Control?
Zdenek
(3,362 Views)
