labview 2010 E4406 1XEVDO/CDMA2k driver
We recently purchased labview 2010. I installed drivers for Agilent E4406A VSA but it only installed drivers for WCDMA and GSM. Our product is running on CDMA2K (1xRTT) and EVDO-rA. How can i get labview 2010 drivers for this so i can controll and aquire data from my instrumnet. I was previously using Labview 8.6 and its drivers worked fine and all of the code i already have is written on 8.6 and drivers are great. The drivers i downloaded from the instrument driver search for labview 2010 are Agilent PSA (GSM) series and Agilent PSA (W-CDMA) series. No other options for EVDO or CDMA2k show up. Please help.
Shad
(4,077 Views)
copy the drivers from your 8.6 instr.lib for the selected instruments to your labview 2010 instr.lib directory and off you go.
greetings from the Netherlands
(4,076 Views)
i did and it looked like it would work untill it stared looking for a dll called "hpe4406_32.dll"     And thats where i am stuck with no other tricks. Thanks for prompt reply.
(4,074 Views)
I have also done a search for that particular .dll file on my previous instr.lib fiolders with no luck.
(4,073 Views)
Accepted by shaddie
The dll might be anywhere on your system, maybe in the windows system directory or system32
(4,068 Views)
AMEN to that. I searched my main PC and found it on this directory C:\ Program files\IVI foundation\VISA\WINNT\Bin
I copied it and installed it on the machine i am using and it worked like a charm. Thanks a lot. I really do appreciate.Smiley Very Happy
(4,063 Views)
