labview & testo toolbox
Dear Markus,
Thank you very much for your help. I also received the link and downloaded the complete toolbox software.
I don't know the 8pin mini DIN connection details also. I have written TESTO Germany for that. Hopefully I will get positive reply.
What kind of output connector is provided in TESTO 950 which you are using for communication with PC?
With regards,
Prasun
Message 31 of 68
(3,426 Views)
It is also an 8pin mini DIN to RS232 D-Sub9.
Message 32 of 68
(3,422 Views)
Can you tell me the 8 pin mini DIN to RS232 Cable PIN connection? I know I am asking too much but it will be a great help!
Prasun
Message 33 of 68
(3,417 Views)
I'm using a testo 350xl control unit and three testo 454 data loggers connected to it. I would like to acquire data programmatically from all the connected devices.
The t35 gas analyzer example.vi of the testo toolbox works fine, but it lets me to access data of only a device at time. The problem is that the device has to be selected by a pop-up menu that is not from LabVIEW. So I have to make a manual operation each time the method Itcddk.init is called.
Do you know if it is possible to make the device selection in a programmatically way?
Thank you in advance,
Andre
Message 34 of 68
(3,335 Views)
I am trying to acquire data using 't350 gas analyser example.vi' I am getting "Instrument not responding" error in testo serial init vi. Attached is the snap of front panel. The engineer from Germany suggested trying changing the device name to match bus address of my instrument e.g testo350-454$025 if the bus address is 25. But changing this name causes 'Invalid device name error".
Can anybody advise me what could be the issue? It seems some people resolved the issues related to toolbox and Labview communication.
Thank you,
Rupesh.
Message 35 of 68
(3,280 Views)
Hi!
Please, take a look at the message on the right of the form "select device" you filled. You can try to go directly to the block diagram to hardwire the string to the init method.
Andre
Message 36 of 68
(3,269 Views)
Hi Andre,
Yes I tried to direct wire the device name string constant to ActiveX node where orginal case structure was wired but still receiveing error "Instrument not respoding". Can you send snapspot of block diagram you are using for 'testo serial init'. I guess yours is working so I can compare what am I missing?
Thank you for the post,
Rupesh.
Message 37 of 68
(3,267 Views)
Here it is the snapshot.
Remember to define the string testo350-454 $029 in  the file comsoft.cat. it should be in the folder c:\program files\common files\testo shared.
Message 38 of 68
(3,264 Views)
How can I open combatants to do this change? Seems like a security catalog.
I noticed in your block diagram, the device name constant has space between testator-454 and $024. Is there particular reason? The VI that came with toolbox had no space in this name when I was looking at all the devices from drop down menu. Just curious.
Thanks again.
Message 39 of 68
(3,233 Views)
Sorry about the spelling mistake.
I wanted to ask 'how can I open comsoft.cat?'.
Message 40 of 68
(3,187 Views)
