labview and serial comms with dmm
No, it should be after the last write and before the read. In your example, just add another sequence at the end and put a wait (ms) in there. Start with a wait of 100 msec and see if that works.
Message 31 of 39
(2,357 Views)
i put in a wait (ms) block in a new frame in the write block.  i just keeps switching (the dmm), clicking and nothing happens. looks like i did this wrong. or haveent use the ms correctly. i joined one end to the sequence frame and the other i put in a numeric value (100 in this case)
Message 32 of 39
(2,356 Views)
It should look something like the attached. I also modified the sequence structure to show you the correct way to pass data from one sequence to the next.
Message 33 of 39
(2,336 Views)
hey dennis
still no luck, every 100ms the dmm 'clicks' and you get no reading , nothing! when it runs in debug mode it does work. weird.
when i deleted the time delay it worked as per before, jumping up and down .so looks like back to the drawing board!
Message 34 of 39
(2,323 Views)
You might try increasing the delay. Running a VI in execution highlight mode really slows down a VI and if it works there, usually indicates that a there is not enough delay. Try something very high like a couple of seconds. If it you find a setting that works, you can start backing off until it stops reading.
Message 35 of 39
(2,324 Views)
ok, i seem to have some progress, i changed the delay to 7 seconds, and it worked as required, no jumping and it reacted to changes in the volts.
but when i exited the program and ran it again, it didnt work? i was grabbing a screen shot of the graph, but due to some settings on this computer i couldnt save it. so anyway, it was working correctly for a period of time, say a minute, then it justs stops reading and stays at zero volts. if i kept it running it perhaps would have picked up again and but theres still something out. do i need a wait before the read block?
Message 36 of 39
(2,319 Views)
hey dennis
i have solved the earlier issue, it was to due with the write command inside the loop, i moved it outside the loop and now it doesnt 'jump', now i got a problem , another one! i get nothing coming out of the string converter block, i get some weird square blocks before the reading, say [][][][][]4.9v   etc...... then coming into the graph i get nothing, so it seems these [][][][] blocks are a problem, any idea whats going on?
thanks
eric
Message 37 of 39
(2,266 Views)
ok, you can ignore all that! i loaded the program again, works ok, looks like gremlins!
thanks for the help, i got 3 different graphs, alot of mess. how can i get current and volts on 1`graph? i have power on a seperate one,
regards
Message 38 of 39
(2,268 Views)
Hi Toffee,
You can use the bundle function, or merge signals function.  A better way to do this is to use the mixed signals graph.  If you want to post your current vi and I will be able see exactly what you mean.
Hope this helps,
Seamus
Message 39 of 39
(2,158 Views)
