lecroy 104mxi-a configure labels for traces through GPIB
Does anyone know how to manipulate the labels through labview GPIB?  I cannot find a command in the manual that would allow me to add a label.  I also need to position the label as well.
(3,949 Views)
Accepted by 2muchwork
The command for this will be an "Automation" command that is written with the "VBS" remote control command.
To address the label on a channel (call it Cx):  VBS 'app.Acquisition.Cx.LabelsText = "put your text here"'
Notice the single quotes around the "Automation" command.  The VBS command is a remote command (written as a string to the device) and the Automation commands are Visual Basic objects.  The VBS command tells the scope to interpret everything between the single quotes as if it was being addressed directly from a VBS script.
You will also want to turn on the labels:  VBS 'app.Acquisition.Cx.ViewLabels = True'
The value can be:  True, False, or -1(true),0(false).
Cheers,
Leonard Brown
Applications Engineer
TeledyneLeCroy
(3,946 Views)
