09-27-2015 11:08 AM
Good day everyone,
I am using Lecroy 6051A scope and it seems to me, that saving waveform works too slowly. I have written a program for my Lecroy and there have a loop with N=100 to save 100 waveforms. It takes around 20 seconds to do so, which, as it seems to me, is too much. I want to be able to save at least 20 waveforms in 1s.
I have attached my vi. I use 1 channel, timebase was 200 ns/div (250Ms/s). I was advised to use VICP descriptor instead of TCPIP, as it should work faster with VICP
I was trying to delete all the vis in my programm except for those in the 'for' loop, but still it was almost 20 seconds to save 100 waveforms. I am new in working with Labview, maybe I am doing smth wrong, could anyone help me please?
09-27-2015 11:46 AM
Your timebase is irrelavant. How many datapoints per waveform?
09-27-2015 02:03 PM
09-28-2015 08:28 AM
Hallo Albert, greetings from Germany,
here I attach one of these 100 waveforms in csv format - there are 500 points. Actually in this file its only amplitude points, but I can save amplitude with time, but the saving time doesn't change much. Do you think its ok?
I am not sure how to measure TCP/IP speed as you say. But I used speedtest.net to measure upload speed, which is 7.44 Mbps and download speed = 6.17 Mbps
09-28-2015 08:29 AM
hi nyc,
I have 500 points for the waveform
09-28-2015 02:08 PM
