hi,
the manual is at:
http://www.gesensing.com/downloads/manuals/lem_1d01.pdf
COM1:9600,N,8,1 no handshake is the serial port config
You can install a free software for RS-232 screen dialog
(www.labtab.com) or use a GPIB controller manufacturer tool that
supports RS-232; then you have to experiment with sending string
commands and see the responses ...
Normally this is only a 3 strings (P,T and humidity ) affair.
Though Ruska is not "highly" user friendly in communication ;=) they
achieve high accuracies that gives you an advantage over other labs so
this is worth your time on the long term ...
On their portable units for pressure I remember that they are in the
1E-5/year long term drift ! You may have an arcane jewel ...
FG
