GPIB (NI-488.2 15.1) on openSUSE 13.2 Linux 64-bit
I'm trying to install the latest GPIB drivers (NI-488.2 15.1.0f0) on openSUSE 13.2 (64-bit). I followed the extra steps (FAQ #6) for openSUSE in the README.txt.
After doing so, and attempting to run the INSTALL file, I receive the following error. Does anyone know how to proceed? Thanks!
NI-488.2 version 15.1.0f0
is about to be installed using rpm at /usr/local/natinst
Would you like to continue? [Yn]
Installing NI-488.2 version 15.1.0f0...
Pre Installation .
Post Installation .
Pre Installation ...........................
Preparing...                          ################################# [100%]
Updating / installing...
   1:labview-2014-rte-14.0.1-4        ################################# [  6%]
   2:nissli-14.0.0-f0                 ################################# [ 11%]
   3:nimdnsresponder-14.0.0-f0        ################################# [ 17%]
   4:nipalerri-15.0.0-f0              ################################# [ 22%]
   5:nikali-15.0.1-f0                 ################################# [ 28%]
   6:nipalki-15.0.0-f0                ################################# [ 33%]
   7:nipali-15.0.0-f0                 ################################# [ 39%]
   8:ni4882ki-15.1.0-f0               ################################# [ 44%]
   9:nitargetcfgi-2.0.0-f1            ################################# [ 50%]
  10:nisslcerts-14.0.0-3.0            ################################# [ 56%]
  11:nicurli-14.0.0-f0                ################################# [ 61%]
  12:nisyscfgi-15.0.0-f0              ################################# [ 67%]
  13:nispyi-2.8.1-f0                  ################################# [ 72%]
  14:niiotracei-15.0.0-f0             ################################# [ 78%]
Could not parse file "/usr/share/applications/natinst-nivisa-readme.desktop": No such file or directory
Could not parse file "/usr/share/applications/natinst-nivisa-visaconf.desktop": No such file or directory
Could not parse file "/usr/share/applications/natinst-nivisa-driverwizard.desktop": No such file or directory
Could not parse file "/usr/share/applications/natinst-nivisa-visaic.desktop": No such file or directory
Could not parse file "/usr/share/applications/natinst-nivisa-help.desktop": No such file or directory
Could not parse file "/usr/share/applications/natinst-nivisa-server.desktop": No such file or directory
  15:ni4882i-15.1.0-f0                ################################# [ 83%]
  16:ni4882i-32bit-15.1.0-f0          ################################# [ 89%]
  17:nisyscfgi-32bit-15.0.0-f0        ################################# [ 94%]
  18:nipali-32bit-15.0.0-f0           ################################# [100%]
Post Installation .
Warning: nikali post installation failed! /tmp/nikaliPostInstall.log follows:
Configuring NI-KAL for kernel version 3.16.7-24-desktop...
Building module nikal...
 nikal successfully updated.
nm: '/usr/local/natinst/nikal/etc/clientkdb/nicore/nidimk-unversioned.o': No such file
strings: '/usr/local/natinst/nikal/etc/clientkdb/nicore/nidimk-unversioned.o': No such file
nm: '/usr/local/natinst/nikal/etc/clientkdb/nicore/nimdbgk-unversioned.o': No such file
strings: '/usr/local/natinst/nikal/etc/clientkdb/nicore/nimdbgk-unversioned.o': No such file
nm: '/usr/local/natinst/nikal/etc/clientkdb/nicore/nimxdfk-unversioned.o': No such file
strings: '/usr/local/natinst/nikal/etc/clientkdb/nicore/nimxdfk-unversioned.o': No such file
nm: '/usr/local/natinst/nikal/etc/clientkdb/nicore/niorbk-unversioned.o': No such file
strings: '/usr/local/natinst/nikal/etc/clientkdb/nicore/niorbk-unversioned.o': No such file
nm: '/usr/local/natinst/nikal/etc/clientkdb/nipxi/nipxigpk-unversioned.o': No such file
strings: '/usr/local/natinst/nikal/etc/clientkdb/nipxi/nipxigpk-unversioned.o': No such file
nm: '/usr/local/natinst/nikal/etc/clientkdb/nipxi/nipxirmk-unversioned.o': No such file
strings: '/usr/local/natinst/nikal/etc/clientkdb/nipxi/nipxirmk-unversioned.o': No such file
nm: '/usr/local/natinst/nikal/etc/clientkdb/vxipnp/NiViPciK-unversioned.o': No such file
strings: '/usr/local/natinst/nikal/etc/clientkdb/vxipnp/NiViPciK-unversioned.o': No such file
nm: '/usr/local/natinst/nikal/etc/clientkdb/vxipnp/NiViPxiK-unversioned.o': No such file
strings: '/usr/local/natinst/nikal/etc/clientkdb/vxipnp/NiViPxiK-unversioned.o': No such file
Building module nidimk...
nikal: make: *** No rule to make target '/usr/local/natinst/nikal/etc/clientkdb/nicore/nidimk-unversioned.o', needed by 'nidimk.ko'.  Stop.
nikal: ERROR:  failed to build nidimk
nikal: ERROR: Update of National Instruments drivers failed.
Updating modversions database to include newly installed drivers...
FOR PATENTS COVERING NATIONAL INSTRUMENTS PRODUCTS, REFER TO
THE PATENTS.txt FILE ON /home/ralph/Desktop/NI-4882 AND/OR
www.ni.com/patents
* A reboot is required before attempting to use the
* NI-488.2 software.
Would you like to reboot now? [yes|no] no
NI-488.2 Installation completed with errors.
Please reboot manually before attempting to use
NI-488.2 software.
(5,302 Views)
Cj12345,
Based on others which have received a similar error, it occurs when the file names have changed for some reason.
Is there a potential that file names that it is looking for have changed for some reason or have been moved to a different location?
The other thing I would try is to see if you could download it without getting these errors on a different Linux 64-bit to see if the error is replicated.
Out of curiosity when you restart the computer, and try to use the driver are there things that occur which are not expected behavior? The reason I ask is because it says that it installed, but it has errors and I wanted to know how those errors affected the functionality.
Also have you tried to install 488.2 driver multiple times and does the same error occur?
Sarina
Applications Engineering
(5,272 Views)
All of the error messages displayed are related to NI-VISA, or dependencies which would be installed by NI-VISA. Since NI-VISA is not installed by the NI-488.2 installer, it seems you have remnants of an older NI-VISA installation which may not be working correctly.
I would suggest you re-install NI-VISA (Or uninstall it, then install it again). You can obtain NI-VISA from a sub-folder of the NI-488.2 installation media, or by downloading it from ni.com.
(5,207 Views)
