07-28-2006 01:22 PM
07-31-2006 07:17 AM
MAX will identify your device with the SCPI command *IDN? , but if your device don't know that request, how should MAX know?
A brief RTFM look into the manual might give you an answer if the LEM 4000 understand the IDN
Have you searched the NI driver lib, maybe there is already a driver for your instrument. If not contributions are wellcome 😉
09-01-2006 04:56 PM
09-05-2006 08:06 AM
Thanks much for the reply,
I have recently found out that it simply is a setup in the LEM that is not in the user manual. It works no problem at the moment.
WV
