multi GPIB controller
Hi Guys,
  I want to build a GPIB structure which will have several controllers to controll several instruments. like the figure shown below. Is it possable?
(4,169 Views)
ghlaah,
No you can't do want you have shown above. You can only have 1 GPIB controller-in-charge at a time on a GPIB bus. You want to be able to communicate from Client 12 with the SG at the same time as Client 14 communciates with the DMM - not possible.
To accomplish this you can either make sure all the instruments have LAN ports and just have  a totally Ethernet system or alternatively you could replace the GPIB Hub, you show, with an Ethernet -to-GPIB controller. All the Clients hook up to the Ethernet-to-GPIB controller via Ethernet and all the instruments connect to the GPIB side. This should work according to NI's data sheet for the NI GPIB-ENET/100.
(4,152 Views)
Another option besides the GPIB-ENET/100 controller, is to connect all the instruments to a GPIB interface on one of your computers, then use NI-VISA Server to allow remote access to those instruments over ethernet.
-Jason S.
(4,138 Views)
And whatever scheme, you had better think about how to prevent user A and user b from trying to program the same instrument.
(4,131 Views)
