myRIO Serial Connection custom baudrate
I want to set my custom baudrate on myrio, My sensor baud rate is 200 K which I want to connect directly to myRIo UART port, however , I can not set my badrate in labview to 200 K. It shows I can only save my baud rate in  multiplication of 9600. So is there anyway to set my custom baud rate ?
(3,232 Views)
Accepted by topic author shank16
Hi shank16,
There will not be a way to do this in LabVIEW by simply configuring the port baud rate, you will most likely have to set up a custom serial interface in the FPGA VI. You should be able to just read the digital lines from your sensor and use the FPGA to set up the timing. I would look to the follow document as a good place to get started.
Developing Digital Communication Interfaces with LabVIEW FPGA: http://www.ni.com/white-paper/5385/en/
Conrad
Applications Engineer
(3,178 Views)
