norma 950 driver
I have a model 950 dmm.from Norma.
I have this questions,
First one,it's possible to integrate the dos driver in Labview?
The second is it possible to find a labview code?
Thank's in advance.
Nicola
Bytelabs.it
Message 1 of 12
(4,393 Views)
Hello Nicola,
1. If you have a C source code of the driver, I believe there is a way to integrate it with LabVIEW.
2. I work for a company which has been developing drivers for LEM for many years. The info from them is that they do not support this instrument anymore and do not have any drivers. 950 was in fact made by GMC, but they do not seem to support this instrument any more as well. I am pretty sure they will not have any LabVIEW driver for this instrument as most (if not all) LabVIEW drivers for GMC were written at our company. If you need the LabVIEW driver real bad, you can either write it yourself (using NI driver development guidelines) or you can have it developed, for example at our company.
Jan Sima
Message 2 of 12
(4,393 Views)
Hello,jan
I would like build this driver in LV.The problem is i don't have a protocol and set instructions.
If i have this,i'll try to build the LV code.
I need to chenge the unit from DCVolt and DCAmpere.I have 4 instruments which start sinchronous measure.
Thank's for your answer.
Nicola
Bytelabs.it
Message 3 of 12
(4,393 Views)
Nicola:
I sent an email to someone I used to know at GMC, but do not know if this will work. In the meantime, you could try if you can extract the commands from the DOS driver that you said you have.
Jan
Message 4 of 12
(4,393 Views)
Thanks,Jan
I have find a manual user in doitch language.
The set instruction is clear.
Is not clear how control the port,
Is possible to connect RX/TX GND pair?
Is possible to set the FlowControl with Xon/Xoff?
If you have more information i thank's in advance.
Nicola"
Bytelabs.it
Message 5 of 12
(4,393 Views)
Nicola:
In general, there are 3 possibilities for Flow Control:
1. None
2. Xon/Xoff
3. RTS/CTS (Hardware)
You have to find out in your instrument's manual which method is supported by the instrument. If you can not find it, then you have to experiment. Also, make sure your other serial port settings match (baudrate, databits, stopbits, parity).
Jan
Message 6 of 12
(4,393 Views)
thank's,Jan
In effect i will do experiment because i don't have the manual instruction.I wishes i find it.
Kind regards,Nic
Bytelabs.it
Message 7 of 12
(4,393 Views)
Hi Jan,
How is possible to find the english version of the manual?
With the german manual i can't read clear.
If you have the english version i would thank a lot you .
Hi Nic
Bytelabs.it
Message 8 of 12
(4,393 Views)
Nicola,
Unfortunately, I do not have any manual for this instrument. Strange thing is that the person from GMC told me that it is not GMC product either. So I am curious who really designed&manufactured this instrument. Anyway, it looks like you will have to use the German manual after all. I do not speak German, so I can't help you. Sorry.
Jan
Message 9 of 12
(4,393 Views)
Ok,Thank's the same.
Do you know the GMC internet adress?
I'll try to call them.
Kind regards
Nicola
Bytelabs.it
Message 10 of 12
(4,393 Views)
