old instrument won't talk on new pc
My problem is partly covered in document ID: 0R0FC772 at
http://digital.ni.com/public.nsf/allkb/862567530005F09C852563D5007598C4
My Ultima Labmaster optical power meter responds to write commands but times out on read commands. My question is can I write my own driver to access the GPIB card? Is there any template for this or sample code to start from?
Oliver
(3,889 Views)
You want to write your own drivers for your National Instruments PCI-GPIB interface? This cannot be done, and I am not sure if this will help your application.
Did you insert delays between the writes and reads  or slow down the baud rate as suggersted in the article you linked?
Peter Flores
(3,860 Views)
adapting the bustiming to 2 microseconds seems a better option than baudrates for a gpib interface.
You can do that in MAX in devices gpib settings.
greetings from the Netherlands
(3,855 Views)
Thanks for the correction 🙂
I meant bus timing, NOT baud rate!
Peter Flores
(3,840 Views)
Adding delays didn't help. I also tried the slowest bus timing and it still wouldn't respond.
I decided to use the RS232 interface instead of GPIB. It works fine this way.
Thanks for the suggestions.
(3,835 Views)
