GPIB USB HS will not work on 3 PCs. Did work on old PC.
I have a GPIB-USB-HS that I have use before on my older laptop. I have refreshed to a new laptop and the it will not install. I keep getting a message that it can not find the drivers. I have installed the visa430full.exe and when I try to install either ni488225.exe or ni488227.exe it has a message the there is a legacy version 488.2 and remove it. I have done this with the Add Remove Program in windows. It still says that I have a legacy version 488.2. What do I need to do to fix this? I need to get it fixed soon as I am to start a test. I am using Labview 7.1 (I know it is the old version) and Windows XP sp2 on all 3 PC’s, 2 laptops one less than a month old and one desktop.
I appreciate any help.
Gerald
(4,615 Views)
Well I finally got the drivers to install and recognize the GPIB adapter but I am now getting errors on code that worked before. I think I have jacked around and changed or deleted too much in the process. I have read about NI software that would completely remove everything so I could do a clean install and add the updates correctly. Could someone please let me know where to find that? I found this in a thread that helped me figure out what I was doing wrong (Control Pane>>Add/Remove Programs>>National Instruments Software>>NI-488.2). I did not know that is would open another menu and you could select what you wanted to remove. That was about 9 hours to learn a valuable lesion one that I will not forget.
(4,590 Views)
It might be a bit radical but was this the tool you were looking for?
http://forums.ni.com/ni/board/message?board.id=250&message.id=34373&requireLogin=False
Now Using LabVIEW 2019SP1 and TestStand 2019
(4,582 Views)
Accepted by topic author antique
Thank you for the response. I did get it to work and it is working great. I did uninstall and do a fresh reinstall on one laptop and on the other PC’s I just uninstalled the NI-488.2 and reinstalled the 2.7 version. I had tried to install the 2.7.1 version and in you links there was a chart for compatibility. That was very helpful since I could not use the 2.7.1 with the labview 7.1 software.
Thanks again for the help and this  issue is solved.
Gerald
(4,568 Views)
pleas kudo the accepted solution, not your own thank you.
greetings from the Netherlands
(4,565 Views)
I guess I did not see the rules or guidelines on how to end the thread I am sure glad you corrected me. I will try and do it correctly next time. Thanks Gerald
(4,561 Views)
